clear l2pt counters vman
clear l2pt counters {vman vman_name {ports port_list}}
Description
Clears L2PT VMAN counters.
Syntax Description
vlan Optionally clears counters only on a specific VLAN.
vman Optionally clears counters only on a specific VMAN.
vlan_name Specifies the VLAN name.
ports port_list Optionally clears counters only on specific ports of the VLAN/VMAN. The port list is separated by a comma ( , ) or dash ( - ).
Default
Disabled.
Usage Guidelines
Use this command to clear L2PT VMAN counters.
The following example clears all L2PT counters:
clear l2pt counters
The following example clears L2PT counters on VMAN vlan2:
clear l2pt counters vman vlan2
This command was first available in ExtremeXOS 15.5.
Platform Availability
